Define color of "Related Articles" and "More from author"
Hi, please provide to me css code to define colors for the mentioned sections:
#cc092f and hover #22588D
Hello wdziedzic,
Try to use the code below and place it in Theme panel -> Custom CSS area.
.td_block_template_1 .td-related-title .td-cur-simple-item {
background-color: #22588D!important;
h4>a{
color: #cc092f;
The result is here -> https://www.screencast.com/t/H8J8mMuIHw
Hello Catalin,
I ment the font color, not background color but I already adapted the provided code.
It looks good but is not what I wanted to have 🙂
The idea was: font color: #cc092f and font hover:#22588D (for both – related articles & more from author). No Background color (should stay white as it is now)
Could you please provide me the code?
Hello wdziedzic,
Please use the Inspector Browser and try to create yourself the code you want to achieve because we cannot provide additional customizations, sorry! Check here -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
