Delete comment block on Home Page
Dear
Suddenly a comment block has appear in my home page.
I had try to delete it but I cannot
The problem https://www.infoh24.info/wp-content/uploads/2020/10/home-2.png
you can find the problem on the website above the footer http://infoh24.info/
Can you advise please?
Is possible to have the general option or comments enable on pages, normal our theme should disable it because we use it only for posts.
Here is a guide for how to disable the comments from pages: How to enable / disable comments in pages in WordPress ?
Hope this will help you!
Dear Calin,
Thanks for your support.
It’s ok.
You can close the ticket
