Delete "more from author" from related posts module
Hi there guys
I’m wondering how to delete the tab at the bottom of my posts
which links to author posts.
I only want to show related posts by tags not by author.
Many thanks.
  • This topic was modified 6 years by vlad.
Hello !
That option cannot be removed. You can create a cloud library template which will be fully customizable using the tagDiv Composer as you can see here: https://www.youtube.com/watch?v=I1R3j1QYod0
ok thanks
