I would like to remove the small comment box that appears next to the title of the news.
The normal comments I have uninhabited, but I can not find a way to remove this small black block, which also appears in most news number 0.
In which route can I edit this small box?
This is the page: https://www.sophiadigital.es/
You can see in the first three news that little black box with the 0 blank …
Thank you 🙂
Hello !
That can be removed by going in Theme Panel – Block Settings – Meta Info on module / Blocks as you can see here: https://www.screencast.com/t/zZqfevZdnAX
