Demo layout not exactly same after installed
I’m referring to Lifestyle Blog demo, https://demo.tagdiv.com/newspaper_blog_lifestyle/
Here is my live blog using this demo content after installed, https://www.cikhijau.com/
I noticed 2 major differences after installed the demo compared with the one in your demo site.
1. If you click at the each post details page, you can see the differences of the layout. How can I get the exact layout as your demo?
2. In mobile view, side menu, when click the 1st level menu, it’s not working (not opening any page), different from your demo site which is working fine. And for nested menu (2nd level), it’s working (opening the related page) but the layout of the page is different from your demo site. How to fix this?
Really appreciate your helps & advice.
Thanks in advance.
Regards
Please activate the tagDiv Cloud Library, (the temple from post is from this plugin).
Also please read this topic -> https://forum.tagdiv.com/topic/lifestyle-demo-isnt-loading-the-same-template-in-my-posts/
