Design issue on mobile
Suddenly, of course not suddenly but I can’t remember making a change exept for regular updating the theme, the design is broken. On desktop it is fine but on the mobile phone it’s not. Do you have a solution?
Check the screenshot: https://1drv.ms/i/s!AhUKbdwKStf_uQmQnrIFdkfsMRlj
  • This topic was modified 8 years by _edwin_.
Hi Bogdan,
I disabled everything exept WPBakery Page Builder. Still the same issue.
There is an issue with the responsive version of block 16, we are aware of this problem and it will be fixed in the next theme update. In the meantime as a quick fix, please enter this code in Theme panel->Custom CSS section it should fix the issue
https://www.screencast.com/t/r7zU23th2
@media (max-width: 767px) {
.td_block_16 .td-block-row [class*="td-block-span"] {
float: left;
Sorry for this inconvenience.
Fixed! Thanks!
