Design Options Post Loop Settings
Is there a way to adjust the design options like we can on the Big Grid settings? I am trying to adjust the padding of this section to move the Related Articles closer together. Thoughts?
On the homepage when I click post loop settings I am using the M3 template. I just don’t want them so spaced out.
HI
I am not really sure what you’re trying to so please provide your site url and more specific details about the desired result, also a screen would be helpful, so we can have a closer look and get back to you with a more accurate answer.
On my main page I have A Big Grid setup and nothing else. Then just the Related Articles underneath. I am wondering if there is a way to adjust the spacing between the related articles so they look a little more uniform. See screenshots below.
https://postimg.org/image/wvll10rwb/
https://postimg.org/image/7quknlsfv/
Trying to eliminate some of the white space in-between the thumbnails.
HI
The spaces between columns are quiet fixed because there are some of main theme’s containers and the layout can’t be changed to much there. The values for margins and padding are calculate to fit wherever that container is sued and by changing them site’s layout may be affected.
