Desktop and mobile cloud templets problems with caching.
Hi, i have problems with the desktop and mobile. Caching work by creating a copy of the page when an URL is visited for the first time. And the cached versions are always stored by the pages URL. It caches the first viewed template ie if you open the Site on Mobile it caches Mobile template and shows the Mobile version on Desktop too.
So what I’m trying to do now is delete mobile templates from cloud templates so that it only uses responsive css.
But this was not as easy as I thought then after I deleted mobile temples, so theme thinks I still use them and show me a blank page instead.
All cache has been deleted (I have also changed the caching filenames to see if this resolved the issue without success)
Can you help me?
If you have set up a mobile page you can easily shift or select no mobile pages. But if you delete it, then the mobile page is already there but blank. So, in this case, you need to assign another mobile page, and then select no mobile pages => https://www.screencast.com/t/ynhZy7SNOqh without deleting the previous one. After selecting no mobile pages, you can delete also the mobile pages which you created.
In conclusion, don’t delete first so you will don’t have any issues.
The problem was solved, thanks for the feedback.
I’m glad the problem has been solved.
Have a nice weekend!
