Destroyed Header & Many problems with Recent Update!
Why is there no ability to attach Images to this site? HOW do I get help?? Your recent update broke my site, and I need to get it fixed right away please…..
My header has this text showing, it is very bizarre:
[tds_menu_login inline=”yes” guest_tdicon=”td-icon-profile” toggle_txt=”My account” logout_tdicon=”td-icon-log-out” menu_gh_txt=”Get into your account.” tdc_css=”eyJhbGwiOnsibWFyZ2luLWJvdHRvbSI6IjAiLCJkaXNwbGF5IjoiIn19″ f_uh_font_family=”653″ f_links_font_family=”653″ f_uf_font_family=”653″ f_uh_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_links_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_uf_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_uh_font_weight=”500″ f_links_font_weight=”500″ f_uf_font_weight=”500″ f_toggle_font_family=”653″ f_toggle_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_toggle_font_weight=”500″ ia_space=”8″ menu_offset_top=”15″ show_version=”” f_gh_font_family=”653″ f_btn1_font_family=”653″ f_btn2_font_family=”653″ f_gh_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_btn1_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_btn2_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTIifQ==” f_gh_font_weight=”500″ f_btn1_font_weight=”500″ f_btn2_font_weight=”500″ menu_gc_btn1_bg_color=”#ec3535″ menu_gc_btn1_bg_color_h=”#000000″ menu_gc_btn2_color=”#000000″ menu_gc_btn2_color_h=”#ec3535″ menu_gc_btn1_radius=”4″ menu_ul_link_color=”#000000″ menu_ul_link_color_h=”#ec3535″ menu_uf_txt_color=”#000000″ menu_uf_txt_color_h=”#ec3535″ show_menu=”yes”]
See screenshot here:
https://www.dropbox.com/s/z08sp13220na17u/Screenshot%202022-04-18%2007.37.21.png?dl=0
Where is the real support forum for the Developers?
Hi PrinterSmith, from what I see in your screenshot and details that you provided, the problem is that a theme plugin is not enabled. Please install and activate the tagDiv Cloud Library from Newspaper > plugins.
Also, please check to be sure that you have all the theme plugins enable like you had before the update.
