Hi there,
We’ve just purchased the Newspaper X theme, and are assessing the bundled demos to potentially use them.
Therefore, can you please outline the differences between pro and standard demos? Also, is there any downside to starting from scratch?
– challengerbanking
Pro demos are full customize, these are made with cloud templates from tagDiv Cloud Library and can be edit using tagDiv Composer, using standard demos, you do not have access to customize all the elements from website.
Using demos, you can achieve the website layout/design with one push button, but if you wan you can create your own homepage/templates, or edit these from tagDiv Cloud Library.
Therefore the only difference is the time that you need to design the website.
