Different Color for Post Title in different Post Template Styles
I’d like to use the default post template style for most of my posts with a blue post title (i set via theme panel -> theme colors -> posts -> post title color). For some posts i want to use the predefined style 8. But sadly this style doesn’t look very good with a blue post title. So is there any way to make the post title white if style 8 is used and make it blue on all the other styles?
All the best,
Daniel
Unfortunately, you can’t achieve that using standard templates, but you can use Single Post Template from Cloud Library and you can design it with tagDiv Composer https://www.youtube.com/watch?v=6m8-EebnfM0 -> https://www.youtube.com/watch?v=I1R3j1QYod0 or using custom code css.
Hope this helps you!
thanks for getting back and the information.
All the best,
Daniel
