Different design for different categories and posts
Can you please let me know how I can create a different design of the categories list in the category page. I tried adding it via the cloud templates but I am unable to find the filter to filter it to the specific category. Also, I’ll like to hide the date for a category or it’s posts.
You can create a category template that will be used on most of the categories, this will be set as global https://prnt.sc/7RxaX0PI4tqQ then you create one extra template (or as many as you want) that will be assigned individually, for example – https://prnt.sc/YI7ui-Q-beyG
On flex blocks, just make sure that you select teh current category filter https://forum.tagdiv.com/flex-block-settings-guide/ if you are using a posts loop element, this will automatically filter the results based on the template.
