Hi, I’m using the Momentum theme, and I’ve noticed that the order of elements on my page appears differently on desktop and mobile. For example, on this page https://barbarabueno.com/education/, the sections are displayed in a specific order on desktop, but the layout changes on mobile, which makes the page inconsistent.
On desktop, the sections appear in the intended order:
Bachelor of Communication
Web Development Course
Travel Agency Technical Director Course
Tour Leader Course
However, on mobile, the order changes unexpectedly:
Tour Leader Course
I’m looking for a way to ensure that the order remains consistent across desktop and mobile without rebuilding the page. Is there a setting in the TagDiv Composer to fix this, or do I need to use custom CSS?
Thank you for your assistance!
Barbara
Did you set an order on the columns? You can set or delete if you have set there an order on the column please check this guide https://tagdiv.com/flexibility-rows-columns-newspaper-theme/ Also, you can check this option on mobile https://i.imgur.com/nFeP4o3.png
