Sorry, my fault. I noted that there was no problem about the font between post and pages!
However, entering through my smartphone, I noted another discrepance: the font of the theme is different between smartphone and desktop. I provide you a screenshot made with my smartphone:
https://www.screencast.com/t/D1WfV1BnX
if you look at letter “t” you can simply note that the font is different from the one you find using the desktop (below the screen)
https://www.screencast.com/t/UkpDHhDf2R
The latest is the screen of the mobile version made using my desktop, so if you simply look at mobile and desktop version from a desktop it seems there are no difference. But if you make a check through smartphone you clearly can see the difference in the font looking at this link https://www.cibarsidimarketing.it/articolo-di-prova/
I think one font is Helvetica Neue (the one set by me for the entire website). The other one I presume is Verdana or Georgia.
I hope the problem is clear!
