Directory Listing Post Loop Help
I am using Newspaper for a City Wide Directory. I am coming from a custom made theme that I built out many years ago. My site lists restaurants from all over the area. It’s possible to have multiple Post Names as multiple restaurants can be in different areas. In my theme I was able to customize the post loop to include the address. Is it possible to some how do this in the NEwspaper theme? Below is how I need it to look.
  • This topic was modified 3 years by TWDesigns.
Ofcourse. You can build a module template and use it in any page you need: https://forum.tagdiv.com/flex-block-builder-flex-loop-builder/
Awesome! That got me in the right direction. I have ran into one issue and the help links on here keep going to a 404.
How do I display TAGS instead of the CATEGORY inside the custom Module Template? Under the Module Taxonomies section if I put anything other than “category” it gives an error. I want to display all associated TAGS that have been assigned to the post as well.
Copy and paste the link manually or https://prnt.sc/K5EkY9mt1ELL, it should work.
In that module template, you can build a block as you want. In order to display the tag, use the module taxonomies and write post_tag.
I hope that helps you!
the post_tag is exactly what I needed! Thanks
