hi,
the “More Article Box” works only on post pages. it doesn’t work on other pages.
if you want to disable it : http://screencast.com/t/Pit3mk68XGW0
Thanks for you message.
Radu A.
Add this code:
global $loop_sidebar_position;
if($loop_sidebar_position == 'no_sidebar') {
return;
like here: http://screencast.com/t/sUhlOTrHWk
