Hi, can you please tell me how can i disable (remove) the post settings metabox on
I try
remove_meta_box( ‘td_post_theme_settings_metabox’ , ‘post’ , array (‘normal’, ‘side’) );
but no luck…
I need that my editors cant change the settings…
Salutare!
puteti sa-mi spuneti cum pot sa elimin metabox-ul Post Settings. Am incercat cu ” remove_meta_box( ‘td_post_theme_settings_metabox’ , ‘post’ , array (‘normal’, ‘side’) );” in functions.php dar nu a mers…
