Display Ads in Smart Lists using Child Theme
Hello. How to display custom ad or inline ad in Smart List posts?
Is it possible with child theme?
I followed instruction on this: $buffy .= do_shortcode(‘[td_block_ad_box spot_id="custom_ad_1"]‘);
but have no success.
I’ve tested this method on smart-list and works fine on my side. In this example I used smart-list 4: http://screencast.com/t/ZAy5i1cELY9http://screencast.com/t/JNLyStebh3
Make sure you added the file in same path as I did in my example and also check if the ad-code from the ad-spot that you’re using it’s correct.
Note that this customiztions requires basic php coding skills. If you still need guidance on this or you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you as we can’t offer customization services at the moment.
