Hi!
I’m trying to display an Advanced Custom Field value from a post(s) into a block (Flex_1) placed in homepage.
Would like to pass value to meta area of block.
How do I get the data from post to display in meta area? I understand Loop…but i don’t see anyway to collect info..all i see is $this…which i believe is how…
any direction would be great…
is it possible to add_filter into $this.
thanks in advance…bc i’m pulling my f$&(king hair. 🙂
If you do not understand the concept of $this then please read this guide: https://stackoverflow.com/questions/1523479/what-does-the-variable-this-mean-in-php
You can try to use acf’s advice on how to implement it:
https://www.advancedcustomfields.com/resources/how-to-get-values-from-another-post/
I hope this helps.
