Is there a way to display the author as a subtitle for the three smaller images on the right hand side as is the case for the larger image?
Please have a look at this screenshot to see what I am referring to: http://postimg.org/image/kukie6c3x/
I assume it’s a bog grid 2 you are using. That block uses modules mx10 for the small thumbnails. This module does not have author and date added to it in the files as a design choice. You can add them in the file like so: http://screencast.com/t/AGNjYtwAo
Add this code like in the screenshot above:
<div class="td-module-meta-info">
<?php echo $this->get_author();?>
<?php echo $this->get_date();?>
</div>
result: http://screencast.com/t/0OvoXkg6S7o
Bogdan B..
Hi Bogdan
Thank you for your quick response, the result is exactly what I am looking for! The grid I am using is Big Grid Style 4, adding the code snippet to td_module_mx10.php unfortunately had no effect, which module_mx file must I edit for Style 4? Is it also possible to add the author in the miniatures of Block 2 content (the smaller images at the bottom of my second screenshot)?
Thank you for your efforts!
Best,
Dustin
[url=http://postimg.org/image/abxdlbtax/][img]http://s12.postimg.org/abxdlbtax/Bildschirmfoto_2015_11_16_um_10_57_24.png[/img][/url]
[url=http://postimg.org/image/6i3xc6byx/][img]http://s12.postimg.org/6i3xc6byx/Bildschirmfoto_2015_11_16_um_10_57_52.png[/img][/url]
[url=http://postimg.org/image/ssrsc5995/][img]http://s12.postimg.org/ssrsc5995/Bildschirmfoto_2015_11_16_um_10_59_30.png[/img][/url]
You can check this option as a reference for each block to see what module is being used: http://screencast.com/t/HQPtOh7l8
Big grid 4 already has author name and date to it: http://demo.tagdiv.com/newspaper/big-grid-4/ (module mx5)
Please check this option in the theme panel: http://screencast.com/t/mhSaWTrIs if it is set to off, author and date will not show in modules/blocks.
The grid you are using is ‘Big grid slide’ with a style 4 to it as the screenshot suggests. It uses the exact same module mx10. I have tested this again and it works for big grid slide as well: http://screencast.com/t/3bshNZ4saD
The small module in block 2 is module 6. It already has author in the code except it is commented. You can remove the comment and the author will be displayed.
http://screencast.com/t/L0rQm2TQljh – http://screencast.com/t/bG7yEZk0D4
