Display Categories visible not with additional click
Hello all,
For our Website we are using Block 24 (though the question is valid for other blocks as well) and can´t display the categories next to the title as shown in the online showcase (great feature btw 🙂
Showcase Example:
https://demo.tagdiv.com/newspaper/block-24/
In our website the categories are displayed in a dropdown after clicking “more”.
This is set in the “Ajax Filter” of the block settings. But i must be missing something to have the same function as in the showcase, right?
Regards,
Christian
The ajax filter should put the links automatically if you add the ajax filter data. Please use this guide to display content in the ajax filter: https://forum.tagdiv.com/block-settings-guide/
If the filter does not populate properly, please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Hello Bogdan,
also thanks for this answer. Will try it out.
Regards,
Christian
