display images in posts
Hi, does anybody know why all the pictures in posts preview on main page don’t display if I set any article display template except of M1???
thanks
Elena
I’m not quite sure but based on the fact that your image appear only when choosing module 1 layout I believe that you haven’t set an featured image for your posts and therefore your thumbnails which are used by the theme on other modules aren’t created and this is why images only appear when using module 1 as this module displays the content on the posts with together with images added to that post.
Make sure you set an featured image for your posts from here: http://screencast.com/t/vGnim3J8mSv and let me know if you still have this issue afterwards.
Thanks a lot! this solved the issue!
Elena
