Can I display one post per author?
I have set filter by one category but I want to display one post from this category per author.
Can be possible?
On flex element you can exclude posts from authors or display only post on from some authors -> https://i.imgur.com/u3tUxqQ.png but what you need can not be achieved, sorry.
Ok I got it!
For me it will be fine if I could use 5 columns instead of 4. How can I do this?
I have post this https://forum.tagdiv.com/topic/more-than-4-columns/ but didn’t work 100%.
p.s. if I ll use 5 columns I ll display one post from each category – author.
Yes, you can achieve this using tagDiv Composer, for this on your page or homepage you need to use tagDiv Composer, add a row, this can be stretch and you can choose the layout you want -> https://i.imgur.com/pN6vZwR.jpg let’s that you make those settings -> https://i.imgur.com/ISdhMND.jpg now the row is set in 2 but you need it in 5 so you need to set a width in % on each empty column like this -> https://i.imgur.com/aNtYAfw.png -> https://i.imgur.com/vFhzXBl.jpg after that drag an inner row in each empty column -> https://i.imgur.com/FcUVItl.png -> https://i.imgur.com/wUvuvEl.png -> https://i.imgur.com/MlYoS7f.png and in this way you get the 5 columns.
Hope this will help you!
I can’t do it.
When I edit the https://i.imgur.com/aNtYAfw.png then I cannot see the column.
Also I am not sure if the final layout of https://i.imgur.com/MlYoS7f.png will be as right as the other regions (width: 1200px)
Do you want to share the credentials to check this out?
Finally, I did it!!!
Thank you, your info was very useful!
