Display posts and posts excerpts in 2 or 3 columns
Hello, I’m doing some minor redesigns on our website using the tagDiv Newspaper theme and I can’t seem to figure out a solution to display a single post or just the excerpt of a post in mutiple columns, nor could I find a solution while searching the forums.
What I need is to have the content (or in some cases the excerpt) of a post to continue in a second (or third) inner-column.
Is there a solution to this and perhaps some examples or documentation?
Thank you again for the help!
You can set only the excerpt in 1,2,3 columns https://i.imgur.com/22QBlo3.png. The post content you can’t.
Oh ok, the blocks we had selected didn’t have that option. I found those that do!
Thank you very much Anamaria!
I recommend using Flex Block blocks because they have more options https://forum.tagdiv.com/flex-block-settings-guide/
