Hi after upgrade to 7.6 i have problem with display events we us this plugin https://codecanyon.net/item/calendarize-it-for-wordpress/2568439.
in view of events is additional space. Previous versions worked ok.
see img. https://postimg.org/image/bi4lth2p9/
thx
p.s. ALL THE BEST IN 2017 đ
unfortunately if a plugin is not tested to work with our theme that means that it can at some point become incompatible with the theme as the theme and the plugin get updated and code changed. FOr the compatible tested and recommended plugins, we always make the right adjustments on an update release to maintain compatibility. Unfortunately we cannot do this for every plugin out there. Sorry
You can try to test your plugin just with the theme and visual composer to make sure it does not conflit with another plugin as well.
