Display problem with the right bar
Hello
I have a display problem with the right bar on the homepage.
https://normandie.zonelivre.fr/
And the separator does not appear.
But when I activate Tagdiv Composer, it’s good but the display of the images is bad
I left a theme demo but the problem is still there.
And other problem of posting in articles :
Exemple
Do you have an idea to help me ?
Thank you
Hi, I’m getting exactly the same error. My sidebar its on the right side of the page, but it “breaks” its column container to its right side while scrolling, just like jerome’s example.
Any fix?
Thank you
We are aware of that issue with the sticky sidebar, when using WPBakery only. The issue is currently investigated and it will be fixed as soon as possible. It will affect pages and also posts if you used WPBakery to build posts and create sticky sidebars.
If the tagDiv composer is also active the sidebars should function correctly. You could activate the tagDiv composer to fix it temporarily if possible. But that may create problems with WPBakery content.
A solution you could try is these codes that will force the sticky sidebars to the proper widths, for all viewports
– https://www.screencast.com/t/4kTKWFnW
You could give them a try and see if they work for you, let me know
Desktop
.td-ss-row .td-pb-span4 .wpb_wrapper {
width: 324px!important;
iPad landscape
width: 300px!important;
iPad portrait
width: 228px!important;
Sorry for the inconvenience.
Thank you Simion, codes worked just fine.
Yes, I disabled TD Composer a while ago because of that reason.
I hope you find a fix soon, since many of us prefer WP Bakery over TD Composer because of the back end editing.
Greetings.
Hello
It’s ok, thank you
Glad the quick fix worked. This is being worked on as we speak, in the coming update it should be fixed. Sorry again for this inconvenience.
