Display thumbnail in post for M8 Style in specific category
im using STYLE 8 – under “Post Settings” – “DEFAULT SITE POST TEMPLATE” sitewide for my single posts. This Style puts the thumb to the background – but i als need the same Thumb for only one of my categories. How can i display the POST Thumbnails above the Post Title for this specific category?
thx
Hello newtag,
If you want to change the category template for a specific category, you can set this from Theme panel->Categories->Per category settings like this -> http://screencast.com/t/O7jiUlIKCj
Hope this helps!
If is not what you mean, please provide more details about your desired changes.
Thank you for the message!
Hi, no i mean a different thing. Tell me the proper code to echo the thumb in the single post below the main title. Im using the STYLE 8 – you find this setting in the theme panel under under “Post Settings” – “DEFAULT SITE POST TEMPLATE” . This Style puts the thumb to the background – but i als need the same Thumb below the title but not site-wide, just for posts in a specific category…
thx
Hello newtag,
If you want to add the background image in the placeholder for single_template_8 for posts from specific category, please try to edit the td_single_template_8.php file and add this code -> http://pastebin.com/5RW0Nrpw like this -> http://screencast.com/t/NzHoX2gezgR and the result you should see here -> http://screencast.com/t/T86Tj5Ge
Please notice that after these changes you need some additional customizations. If you are not aware the steps in this regard and if you want to display more levels in our theme, please consider hiring a freelancer/developer to do this for you because we cannot provide custom services at the moment, sorry!
Hope this helps!
