I installed Disqus plugin and activated and added my site but in my post I can’t see the Disqus comment
Can you help me to display disqus comment on the post page. What seems to be the problem?
I have enabled in Settings -> Discussion “Allow people to post comments on new articles” still Disqus comment is not showing http://www.softechnogeek.com/top-5-essential-tools-every-blogger-needs/
On your post edit page for the above post, make sure the [ ] discussion meta box is visible, and see if the allow comments box is checked YES.
We used to have DIsqus on our sites but went back to using built-in comments, so I’m a bit rusty.
Maybe a current user has some more insight.
But I do recall all the “discussion” options need to be “on” just as if you were using built-in comments in WP.
In other words, with Disqus off, is there a comment box on the page?
