Disqus Comment System
Hi, I want to install Disqus Comment System on my web. Its compatible with Newsmag theme?
Hello Inma,
Unfortunately, this type of plugin was not tested with our them and we have no idea about the theme behavior with it and also, we cannot say for sure if it will work or not with the theme, sorry!
We used to use it with Newsmag, but then early 2016 we had a lot of problems with it. Not sure if those got resolved. But, it does work just fine with Newsmag. You might have to remove the original comment # element from the author template, but otherwise when it worked it worked great.
We have since joined many sites in removing comment options as mostly spam, in our case.
