Disqus problem
I’ve edited theme using TagDiv Composer and CloudStyle. Everything works except one thing: I missing disqus theme panel. On typical post I have it:
http://przystanekplanszowka.pl/2019/08/fudzi-gra-planszowa.html
on new I have only wordpress comment panel:
http://przystanekplanszowka.pl/2016/10/dominion-imperium-recenzja.html
How can I fix it?
Sorry I saw that I wrote in wrong subforum :/ I have Newspaper theme.
Hello !
Unfortunately i’m not sure what you mean by not finding Disqus on Theme panel. Please note that unfortunately Disqus is not a tested plugin, therefore this is not covered by the support team.
I see it on theme panel. And when I use typical templates it is work. But when I add template from cloud library, then disqus is replaced by wordpress comment system.
I am not sure if saying Disqus “is not a tested plugin” is completely accurate.. more like an “incompatible plugin”. Not sure why TagDiv doesn’t get in touch with Disqus developers, since the platform is popular, and resolve the issue.
Disqus Plugins work with most other themes flawlessly.
Hello !
With cloud from what I have seen on other users you can try this one: https://wordpress.org/plugins/disqus-conditional-load/ It provides a shortcode for the comment section that can be inserted in the template using Column text element.
Thank you for that tip! I enabled that plug-in and now Disqus is now showing up in The Critic template!
I was getting worried that we would not be able to use that terrific template on our new site.
However, that plugin has now broken the preview function in WP. Back to the drawing board…
