I’ve been experiencing an issue for several months where Divi Builder will not load properly on my site.
I am using the Newspaper theme and its associated plugins.
Whenever I click to edit a page with Divi Builder, it simply loads a blank screen. The standard WordPress editor works normally, but Divi Builder does not initialise at all.
This happens on all pages, including newly created ones.
Because of this, I stopped using Divi Builder for some time, but I would now like to resolve the issue properly.
What I have already tried:
Updated WordPress and Newspaper theme to the latest versions
Cleared all cache
Disabled CDN
Disabled caching and optimisation features
Flushed permalinks
The issue still persists.
Could you please advise whether this is a known compatibility issue between Divi Builder and the Newspaper theme, and what steps I should take to properly diagnose and fix it?
Please note that the Newspaper theme is not officially tested or supported with Divi Builder. The theme is designed to work with its native page builder, tagDiv Composer, and all theme elements and templates are built specifically for that environment.
Pages created with tagDiv Composer are not compatible with Divi Builder, and vice versa. Using third-party page builders alongside the Newspaper theme may lead to conflicts, including issues such as the builder not loading properly.
For the best stability and full functionality, we recommend using the theme’s built-in tagDiv Composer exclusively.
