Does anyone knows how to modify fonts in Mobile theme?
So, my site currently has mobile theme options enabled in Tagdiv newspaper theme. Although, font style depends on users mobile phone fonts. But, is there any way to modify them?
Hello !
Unfortunately you can’t modify the fonts in mobile theme. You can try by adding a custom css to your mobile theme from here: https://www.screencast.com/t/VEI2KQla2GhO
That’s nice. I can do it. Thank you for helping me.
Hy Vlad S,
I tried applying custom CSS code. But it didn’t work in my case. Can you please help me a bit by checking the following screenshot. Did I make any mistake? I want to apply Muli fonts comes to under Sans Serif category.
https://www.right-brothers.net/wp-content/uploads/2019/05/Capture.png
Hello !
In order to get your fonts to work I suggest getting them from google fonts since they offer you the complete css code. For MULI you can see here the code google fonts gives you: https://www.screencast.com/t/mlySZ3qrRk
font-family: 'Muli', sans-serif;
