Hello
I would like to disable the use of the thumbnail for exmaple in block2 and use a personal measures to not cut the height of the image. They are all covers of books. I enclose some examples.
http://pocketnews.it/images/pdf/Home_-_Pocketnews_cut_image_of_cover_of_book.jpg
http://pocketnews.it/images/pdf/Home_-_Pocketnews_ok.jpg
Hello !
We recommend you replacing the normal blocks with flexblocks. In flex Blocks you can find this option to set another thumb size: https://www.screencast.com/t/Ywu8xFbYg
