Hi admins,
I have two important problems that I would like to solve.
1. The first one is when I look my website in the cache like googlebot (I use now http://www.seo-browser.com cause I don´t remember the comand to do in chrome) appears two menus. Thinking on the crawl buget, if he has to spend time two crawl two time that menu, is not really good, cause that time can be given to another URLs.
I tested another website that I know who have Newsmag as well and had two menu too.
How I can remove that double menu?
2. I did everyting to try to minify, defer, make them asynchronous and always crash the web. It is the same if try todo the same with jquery.js. Here all my pics of the website dont appears.
All of this affect to the speed to load the website and the pagespeed score.
Thanks a lot!
Have a nice day!
Hello harmario,
Unfortunately, I do not exactly understand what type of menus you are referring to, sorry! Notice that our theme has only one menu for desktop and table and for mobile is the same menu but optimized for this mode. Most likely, your problem happens due to your caching plugin. Try clear all your caches, server cache and use only our recommended plugins. (especially WP Super Cache plugin) If you need more assistance in this regard and if the problem is still there, please provide your website URL and also, some useful screenshots with your problem for a better understanding.
Thanks for your message!
Hi Catlin! Thanks for the reply!
That´s what I saying https://www.recomendacionesytendencias.com/wp-content/uploads/2017/04/two-menus.png
There are two menus when I´m looking the cache and it is not only my website, I analice another sites with newsmag and the have the same problem.
What about the other question about .css files and jquery.js?
Thanks a lot!
Hello harmario,
Please keep in mind that until now we do not have encountered any problem in this case and also, we do not have any bad reports, sorry! Unfortunately, I do not know exactly what type of tool you are using and when the second menu appears. Try to check our demo with this tool and check the results. Provide more details about this, sorry!
Hi, I have the same problem. I have more than 100 links in main menu. Desktop menu and mobile menu are more than 200 links. This is really not a good problem for google bots when crawl in my website. I would like to use just one type of desktop menu and automatically shrink the mobile. I do not need Signin, Menu Social, …Please guide me how to edit.
Hello jony88,
If you do not want to use the Sign in button, notice that you can disable it from Theme panel, like this -> https://www.screencast.com/t/QIbOWU77Gu8m If is not what you mean, provide more details about your problem so I will be able to provide a more accurate response. Also, you can provide some useful screenshots so I can identify your problem regarding on your menus. Also, your link is required for more investigations.
