Double posts
I have a mistake in my category page lifestyle on my website.
Here is the link : http://www.capsule-collections.com/category/lifestyle/
I saw in my category page there are some posts in double. I check and this is the same post ID.
And in the backend WordPress, I just have one post for this name :
– Mariage franco-américain Dodocase et Edie&Watson
– Arc-en-ciel
There is no translation plugin. No commerce part. It’s strange.
Can you have a look please ? Or maybe it’s just an option ? What do you think ?
Bests regard.
Double post
Please try to disable all plugins except visual composer, clear cache and reset cdn if you use it to see if there are conflicting plugins. We have not encountered this issue before so we cannot say for certain where it comes from. Let us know if the problem is still there afterwards.
I found the solution, there is a function who make this problem.
She come from another module who’s named “Simple Custom Post Order”.
So If disable this, it works well.
Thank you and merry christmas.
