1) I had set up block 1 but to display one category only (Pelotas category). But it is displaying others such as “artigos”, “zona sul” and I do not want them.. How to fix? In meantime how to translate the word “All”?
https://www.screencast.com/t/dG06v8cLvuhd
2) I had set up the Authors box but I want to display authors in at least 2 columns. With one column I am wasting space in my homepage. How to fix this?
https://www.screencast.com/t/NLXtqvIC
The word “posts” under authors name how could I change this translation?
my website is: https://pelotas13horas.com.br/
thanks in advance.
Hello !
1. You can set up filters and remove / translate the ALL by editing your block using the tagdiv composer as you can see here: https://www.screencast.com/t/Wec2oFSu
2. Unfortunately that option is not available with Newspaper Theme.
3. Those can be translated by going into Theme Panel – Translations.
I hope this was helpfull !
