drag and drop, in add element, doesn’t work
I have a problem in the “add elements” section in my pages, with the “Newspaper” theme. Everything seems to work with the tagdig composer, the edit page opens perfectly, but when I try to add an element from the section I can’t do any “drag and drop” of the selected element, basically in the composition area after releasing the selected element on the left nothing remains. Could you kindly tell me how to solve this problem? My wordrpess version is 6.6.. All my plugins are updated
Thanks for your support
Max
Do you use Safari? If yes, then you need to use another browser.
