Drop down menu zoom in problem
I have problem when I zoom into a web page (ctrl and + key).
I don’t see drop down menu until the end of it. My last project is “Gastro Lika” and I don’t see it even if I scroll down.
Link: http://lag-lika.hr/ (Croatian language)
I mean drop down menu under menu link “Projekti”
How to fix that?
I really need to sub menu work in zoom in level because lot of older people are watching this web page and they use double zoom in level.
Thank you a lot in advance.
Nice regards, Ira
I could give you a code to reduce the line height of the menu and the top and bottom padding, just for that particular menu item
– https://www.screencast.com/t/59JOdkRQ834
When zoomed in two times (200%) it would look like this
– https://www.screencast.com/t/UuKPWMrnqe4n
This is the code I used, you can enter it in Theme panel->Custom CSS if you decide to use it
.menu-item-4242 ul li {
line-height: 18px;
.menu-item-4242 .sub-menu .td-menu-item > a{
padding: 4px 5px!important;
Thank you a loot!
Works great!
Best regards, Ira
