I cannot get the drop downs to expand to edit fonts. I’ve tried all three browsers on my computer, other computers… it has been an ongoing issue for over a year now and I am not sure how to fix this. They load forever and show as if they’ve expanded but I cannot see any of the options.
Hi vdelaplante,
Usually, when this problem appears you’ll have some errors in the console, usually, something is interfering with our theme. Most o the time it is an extra plugin, therefor I recommend doing a test only with tagdiv plugins. In case the problem persists then it can be a code restriction, this can be set in htaccess files.
