Drop Shadow on text using Column Title block on page?
In TD Composer I’ve figured out how to add a drop shadow to the box around the title using a Column Title block when building a page. Is it possible to apply a drop shadow to the title text instead of the box?
All the effects that can be apply on elements and be found using the search -> https://i.imgur.com/weCxXz7.png ->https://i.imgur.com/PAUulq3.png unfortunately this will be apply only on the box. If I understand correctly, you want to add an shadow on some text like this ->https://www.w3schools.com/css/tryit.asp?filename=trycss3_text-shadow4 unfortunately our theme do not have an option for this, but you can achieve it by using a custom css like this one -> https://i.imgur.com/ajxbpHl.png -> https://i.imgur.com/Qvnetdl.png -> https://i.imgur.com/AHUnz3a.png the code can be get from here -> https://pastebin.com/m1M2MFq3
Hope this will help you!
