Duplicate H1 on Homepage, missing H2 and too many (duplicate) headings at all
After changing to my custom domain I can test now the onpage seo on my blog. Therefore I used seobility.net: https://freetools.seobility.net/de/seocheck/www.topfgartenwelt.com and there are shown up many problems with the headings at all.
1. There is duplicate H1 on the Homepage –> how can I fix this? I created the header with a cloud template, the standard pack is disabled.
2. I used the flexblock 1 to show the posts. In the composer I have set the title tag SEO to H2, but in the audit they are shown up as H3 and they are duplicated. A H2 Heading is completely missing. This is for SEO not good at all. How I can get them to H2 and how I can delete the duplicate headings?
The link to the homepage is: https://www.topfgartenwelt.com
Greetings Kathrin
Hello !
1. You can edit your blocks using tagDv Composer and change the heading as you can see here: https://www.screencast.com/t/l87lIJpXPlJV
2. Please make sure that your cache is clear. This seems to be a cache issue.
Dear Vlad, I have cleared the cache but there is no change. The flex block is set to h2, but it shows a h3 heading. And why there is a duplicate H1? You didn’t answer that question! Here is a link with pictures: https://www.topfgartenwelt.com/newspaper
Greetings Kathrin
I’ve tried to add a new flex block and set it to h2 but that didn’t work too. It doesn’t matter which kind of heading I choose in the tagdiv-composer it always shows a h3. That is really no solution!!!
Why it is just possible to adjust the Title Tag but not the headings that are shown in the flexblocks. They are always h3. Where I can find them in the code to adjust it there? And how I can get rid off the dublicate H1?
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
The duplicate heading in the desktop-version disappears, when you deactivate the H1 from the Logo in the tagdiv-composer…
Greetings Kathrin
