Duplicated posts with "load more" on homepage
I use this homepage lay-out: Homepage blank template -> Big slider (4 posts), block 2 (2 posts) and block 4 (10 posts) with sidebar and block 4 set to “load more” and unique article enabled (screenshot: http://imgur.com/vDQnblV). When clicking load more, the first 6 articles in block 4 will be loaded again before loading new posts. I’ve made a screenshot (http://imgur.com/IsWCFHk), you can see some posts are the same and they are loaded below the “load more” fold.
The reason I use this lay out is because block 4 shows up nicely on mobile. So i hid the big slider and block 2 on mobile (max-width: 767) via css, but now block 4 isn’t showing the newest post. I know it’s because the unique article filter filters the first 6 posts (4 in the slider + 2 in block 2 = 6) from the big slider and block 2. But maybe there is a workaround or fix to make block 4 show up the newest articles on mobile? I know i can turn off the unique article filter but then the homepage on desktop will show duplicated posts. I really need a fic for this.
Isn’t it possible you guys make a second homepage template for mobile only? So you can design a normal homepage for desktop and tablet and a special homepage for mobile?
Thank you for this suggestion, this is a great idea we will try to implement this feature in future updates.
Thank you
You haven’t replied on the duplicated articles when clicking on load more. Please provide support!
Unfortunately we know about this issue, if you use load more feature on blocks, the unique article doesn’t work for the new post loaded from the block.
Sorry for this inconvenience
