Hello, I tried to use Easy table of contents plugin on my newspapper theme but it doesen’t work as I planned, My paraghraps started to go crazy, putting random codes in my articles, it’s any way to make it work? I also tried with another table of contents plugin ( Table of contents plus ) but it’s the same problem.
Unfortunately, these plugins are not tested with the theme and we don’t know what settings should be made so as not to interfere with our theme.
The only solution is to try other plugins on a subdomain and see how it behaves.
Thank you for understanding!
Joli table of contents works well with theme Newspaper. https://wordpress.org/plugins/joli-table-of-contents/
I’ve tried Table of Contents Plus, it made 2 tables, one for the post, and one for all the webpage including sidebar and footer.
I found that “Table of Contents Plus” works but not with the Cloud Templates which made 2 tables.
Hello, @Carl Kmetz
Unfortunately, as I said above, we don’t have a tested plugin for tables, but you can try the suggestion made by @tmhai -> https://wordpress.org/plugins/joli-table-of-contents/
