Edit Menu top offset
I would like to modify the Menu top offset (https://i.ibb.co/LR7Dfg6/menu.png). Is there a way to do it via the tagdiv composer?
There is an option: https://app.screencast.com/01rBh9waGUWwg also, an offset option to place it on the left side.
I hope that helps you!
Hello, I tried the padding option but it doesn’t work. I think because the menu isn’t a mega menu, it’s just a sub menu. Is there a way to top offset the submenu (https://i.ibb.co/LR7Dfg6/menu.png)? Thank you!
Try to adjust it by using this option instead: https://app.screencast.com/cYHbqXKLgnjYe
