Edit order posts not working
I’ve tried to edit order posts but nothing happens.
The site is hosted on Cpanel, I don’t know it could be an helpful information.
At this link https://www.loom.com/share/9372ca3b29fd4d1ba1a8ee20b762bc31 there is a video that show the bug on stage.
Thank you for support!
Hi fgentile,
Sometimes this problem appear when you are using other plugins and are interfering with the theme plugins. What I suggest is to make a test using only the tagDiv plugins and check to see if the problem persist. Also, if you made some changes in the theme files or you are using a child theme, then please make a test with the original theme code/without child theme.
Let me know the results!
Hi Calin,
I’ve just tried to use only tagDiv plugin but problem persist. I’m waiting an answer from my hosting society. Perhaps it could be a problem with js editing on your visual builder… I will tell you about
