I am trying to add Google AdSense’s new “In-feed Ad” in the related articles loop in your theme’s mobile version. For now, I was only able to track the file interested for the “loop generation”: Newspaper/mobile/includes/modules/td_module_mob_1.php
The problem is the theme is using some sort of class paradigma and that’s a problem since I want to insert an ad on the second/third position. Here is an illustration: http://i65.tinypic.com/293x24x.png
Hope I was clear enough.
Sorry but we have not tested such ads in our mobile theme. This represents customization and it is not covered by the theme support. We suggest hiring a freelancer if you need help implementing specific ads other than the options already provided in the theme panel.
Sure,
The related articles function can be found here: https://www.screencast.com/t/AhJMvBjQhNZW
You can find the loop that the mobile theme uses in this file
– https://www.screencast.com/t/9xRSsfjo
Sorry about that, I though that this was about the latest articles, my mistake. That is a filtered block that displays related posts
– https://www.screencast.com/t/OEVn0qne
– https://www.screencast.com/t/gaodgo75q
