Edit With TD Composer Not Working
I am not able to edit my homepage with td composer. It just keeps loading. I used it recently and it was working fine but now it’s a big issue. Please help me fix it.
Wordpress 5.5 no longer supports some deprecated code
Consider downloading plugin: Enable-jquery-migrate-helper
This is solving issues for countless themes with outdated code.
Thank you so much for your help. It worked!
There will be soon an update that will remove the those warnings (our developers will change the deprecate code)!
Thank you for your understating!
