Yesterday I updated the theme to the 8.5 and when I wanted to add a RAW html I couldn’t edit the text. Went here to the support and read on another topic about the same problem and the advise given was to install the theme via FTP (I did it through the wordpress), up date the plug-ins and clear the cache. I did all that and now I can’t even open TD Composer editor on the page.
I don’t no what went wrong.
This could be related to insufficient resources, as it is in most cases. Please check the theme system status and make modifications to the parameters mentioned in this guide if necessary
You can ask your hosting to make the changes for you, they might have a recommended method in this matter.
After everything is set properly there should not be any more problems. Let us know otherwise.
