I have reinstalled the whole theme to the newest version, and reinstalled visual composer but I can still not make a post OR EDIT OLD POSTS. I can not place the cursor in the field. Nothing happens. I cannot write or input photo. As I said I have reinstalled visual composer and put in user name and API Key. The wpbaker license code I dont have.
It is urgent that I can update my site today or my visitors goes to another site
Update
When I try to edit a post or make a new post I only get the text version in html with WHITE letters on the WHITE background in the editing frame 🙁
Sorry for the delay! Please make sure that this is not due to other plugins or that you haven’t done other custom changes to your site and also make sure you empty cache and purge files if you use CDN and check again.
Also try to switch to a default WordPress theme like twenty-fourteen or other and see if this is still happening as this could also be cause by WordPress and that is why your issue persists after a theme fresh install.
We haven’t had another reports of this behavior so this can only be due to the theme if it is conflicting with something else.
Please also check your console while editing a post or posting it and let me know if any errors appear.
If you still can’t manage to find a fix for this please let us know and also give us wp-access so we can have a look and provide your wp-admin and FTP logind details at contact@tagdiv.com and also paste a link to this tread in your message.
Hope this helps!
You may want to install one of the plugins which checks overall system usage; meaning telling you which plugins are slowing down the site or using up all your resources.
Also check your site error log (see your hosting provider info on that).
Typically if something won’t load it’s due to php being overloaded, either locally for your site, or the entire server being overloaded by somebody else, and they will likely end up with their site disabled. Downside to shared hosting vs VPS or dedicated box.
The theme can’t secretly turn features on and off for your site. So, you need to debug which of your plugins is causing your php overload/timeout, which would be the reason something like VC won’t work.
simchris.
