have some problems and need help with making a page in editor, first is a problem with deleting a element, nothing happens, this is a error in inspect:
Uncaught Error: ace.edit can’t find div #single_custom_css_ace
at Object.t.edit (ace.js?ver=5.5.1:1)
at HTMLDocument.<anonymous> (scripts-ace.js?ver=5.5.1:9)
at i (load-scripts.php?c=0&load[chunk_0]=jquery-core,utils&ver=5.5.1:2)
at Object.fireWith [as resolveWith] (load-scripts.php?c=0&load[chunk_0]=jquery-core,utils&ver=5.5.1:2)
at Function.ready (load-scripts.php?c=0&load[chunk_0]=jquery-core,utils&ver=5.5.1:2)
at HTMLDocument.J (load-scripts.php?c=0&load[chunk_0]=jquery-core,utils&ver=5.5.1:2)
Also and edit (picture)
And second hot to use a cloud for elements and page in composer
Hi SvijetS,
I do not quite understand, that error appear when you are using tagDiv Composer on a page ? if yes it can be from some extra plugins that you are using, you need to check this, also make sure that you are using the last theme version, Newspaper v10.3.7.
If you want to use the cloud for pages, you can import sections and blocks using this button from here -> https://i.imgur.com/FB7vrUb.jpg these elements will be set at the bottom of page.
Hi SvijetS, I see that on your website https://www.svijetsigurnosti.com/ you are still on Newspaper v10.3.6.1 there is a new version, but I recommend to wait few days until we’ll release a new package, this will have fixes for all bugs that we found. I think that the update will be at the and of this week or at the start to next week.
In case that this problem, is from our theme it will fix, but if is from a plugin, you must check the plugins compatibilities, and is very good that you are using a test website for this, you can use it for updates and all the problems and other problems without affecting the live website.
